1 of 7
Wyze Thermostat
Wyze Thermostat
Smart heating & cooling - simplified.
Regular price $129.99
Regular price Sale price $129.99
Sale Sold out
    Features
    Temperature Preferences
    Keep the temperature where you want it. Temperature Preferences lets you customize 3 settings for when you’re home, away, or asleep.
    Scheduling
    Truly control your thermostat. After setting your Home, Away, and Sleep preferences, use Scheduling to program your thermostat for one week, each individual day of the week, any group of days, or a few hours at a time.
    Auto Switch
    Wyze Thermostat sets the temperature based on where you are, automatically. Auto Switch uses your phone’s Bluetooth to switch between your Home and Away preferences whenever you leave or enter a 3-mile geo-fenced radius around your home.
    Coast to Cool
    Keep it cool, while saving energy. Wyze Thermostat signals your compressor to turn off before the end of a cooling cycle and keeps the fan on to blow the remaining cool air into your home.
    Safety Temps
    Not too hot, not too cold. Safety Temps helps protect your home from extreme cold or hot weather by turning on your heating or cooling system when your set limits are reached.
    Fan Circulation
    Let Wyze Thermostat control your fan independently. This lets air continue to circulate throughout your home without any additional heating or cooling using up energy.
    Minimum Run Time
    Extend the life of your HVAC system. Use the Minimum Run Time feature to set the minimum amount of time the system should run for after you’ve turned it on, even if it’s been manually turned off.
    Swap Heat and Cool
    Refine how Wyze Thermostat functions after setup. If your heating system is turning on your AC, or your AC is turning on your heating when testing the thermostat, this feature swaps the output of the wiring without having to change which terminals the wires are plugged into.
    Works with Alexa (Google Assistant coming soon!)
    Tell Alexa to turn up the heat for you, no need to get up. Wyze Thermostat works with your Alexa-enabled devices to control your thermostat with your voice.
    Sharing
    Ready to let someone else control your Wyze Thermostat? Now that’s trust! Give your friends and family access to your thermostat from the Wyze app.
    Units
    By default, Wyze Thermostat is set to Fahrenheit, but you can change it to Celsius in your Settings.
    Specs
    Here are the requirements for compatibility with Wyze Thermostat.
    Electrical Requirements: 24VAC
    Wires: No need for common (C-wire)
    Conventional (Furnace and Air Conditioning): - Up to 3 stages heat
    - Up to 2 stages cool
    Heat Pumps:
    - Up to 4 stages heat
    Accessory (Humidifier, Dehumidifier, Emergency heat, Ventilator):
    - One accessory support available
    Transformer (Boiler and Air Conditioning):
    - Can support all combinations of dual and single transformers
    Wyze Thermostat Device Details
    Color
    Black and white
    Materials
    Body and back panel: PC+ABS
    Face plate: PMMA
    Dimensions
    Thermostat: 120mm (L) x 65mm (W) x 33mm (D)
    Wall Cover: 165mm (L) x 140mm (W)
    Weight
    <1lb
    3-in-1 Sensor Device Details
    Sensors
    Temperature & humidity
    PIR motion
    Materials
    Face plate: PMMA
    Dimensions
    80mm (L) x 60mm (W) x 16mm (D)
    Compatibility
    System Compatibility
    See the Quick Start Guide.
    Phone Compatibility
    Android 5.0+
    iOS 9.0+
    Display
    IPS Display
    180º Viewing angle
    Power
    Power source
    24VAC through C terminal
    C-wire adapter included
    Power consumption
    <3.5VA
    Sensors
    PIR motion
    Communication
    Bluetooth
    2.4GHz WiFi
    Recommended Temperature
    Operating
    32°F - 130°F (0°C - 55°C)
    5% - 95% RH (non condensing)
    Storage
    -31°F - 113°F (-35°C - 45°C)
    Weather Resistance
    None. Indoor use only.
    Environmental Information
    Certifications
    FCC, IC, and California Proposition 65
    Eco-Friendly
    Recyclable packaging
    Mercury free
    Arsenic free
    PVC free
    Languages
    English
    Warranty
    1-year
    In the box
    Wyze Thermostat x1
    C-Wire Adapter x1
    Back Panel x1
    Mounting Plate x1
    Wall Cover x1
    Wall Screws x2
    Wall anchors x2
    Mounting Screws with anchors x2
    Wire Label Sheet x2
    Screwdriver x2
    Quick Start Guide x1
    FAQ
    Will Wyze Thermostat still work if my WiFi connection drops?
    Yes, Wyze Thermostat will continue operating based on the last updated schedule. You can also control your temperature or change the status from the thermostat itself.
    Is Wyze Thermostat ENERGY STAR approved?
    No, not at this time. We're working towards qualifying for ENERGY STAR approval for Wyze Thermostat.
    How long does it take to install Wyze Thermostat?
    About 30 minutes! And all the tools you need are included in the box, though a power drill might be helpful.
    Does Wyze Thermostat have Alexa built-in?
    Wyze Thermostat works with Alexa, but it does not have an internal speaker and Alexa is not built-in. You'll need to own an Echo speaker (or another device with Alexa) to control your thermostat with your voice.
    Will Wyze Thermostat work with electric baseboard heating?
    No, the thermostat does not work with electric baseboard heating, which is a high voltage (120V or 240V) heating system. Wyze Thermostat was made to control low voltage (24V) heating systems only.
    Do I need to have a C-wire, or “common” wire?
    Yes, the C-wire powers Wyze Thermostat. Don’t have a C-wire? We’ve included a C-wire adapter in the box.
    Is my current wiring compatible with Wyze Thermostat?
    Check your voltage! Wyze Thermostat is compatible with low voltage (24V) systems such as forced air, hydronic, heat pump (including dual fuel), oil, gas and electric. It is compatible with most single-stage and multi-stage conventional and heat pump heating and cooling systems.
    Will Wyze Thermostat work if the power goes out?
    No, the thermostat will not work if the electricity goes out. It will automatically reconnect and resume its schedule once power returns.
    Does Wyze Thermostat work with Wyze Sense sensors?
    Yes, using the Rules feature in the Wyze app.
    I have 2 thermostats in my home. Can I use Wyze Thermostat?
    If your 2 thermostats are controlling 2 different HVAC systems, then yes. You can use 2 Wyze Thermostats to control each system.
    Adjust your thermostat on the go...
    No matter where you are in the world, you’re always just a few taps away from dialing in the perfect temperature.
    • Arrive home to the perfect temperature
    • Save Energy
    • Keep pets comfortable
    • Prevent frozen plumbing
    ...or from the comfort of your couch
    When your morning coffee and blanket aren’t cutting it, adjust the thermostat with your voice by asking Alexa or Google Assistant.
    Schedule your day with Wyze Thermostat
    Simple, daily scheduling. Create schedules for every weekday and weekend so you don’t have to keep going back and forth to your thermostat.
    6:59 AM
    You’re moments away from starting the day. Wake up to a warm welcome - your home has been heating for the last 15 minutes.
    7:30 AM
    You’ve completed your mad dash out the door. Avoid warming an empty house - your home automatically turns heating off, saving you money on energy bills.
    6:00 PM
    You’re home after a long day of saving the world. Arrive home to the perfect temperature - your house began warming up as you left work.
    10:30 PM
    You’re on the last chapter and ready for bed. Enjoy the most comfortable sleep of your life - Your home cools down as you slip under the comforter.
    Receive energy-saving tips based on usage history
    We’ll do the thinking for you.Like an energy-saving gnome inside your phone, the Wyze app will recommend actionable insights based on your usage to help reduce wasted energy.
    A 20-minute DIY installation that anyone can do.
