1 of 5
Wyze Plug
Wyze Plug
A simple way to turn on/off any outlet remotely
Size
Start living in the future. Make your normal old, devices smart!
Features
Command your home with your voice.
When your hands are full or you just don’t want to move, use your voice to turn things on and off by asking your smart assistant.
Control your home from anywhere.
Check the status of all of your Wyze Plugs and turn them on or off remotely so you can avoid high energy bills and fire-hazards.
On when you need it, off when you don’t.
Wake up to the smell of fresh brewed coffee in the morning with Scheduling in the Wyze app.
Custom Scheduling in the Wyze app lets you turn Wyze Plug on or off at specific times of the day so you can have your coffee start at 6:00 AM and turn off at 6:15 AM.
Manage an entire room with grouping.
Grouping in the Wyze app lets you connect multiple Wyze Plugs to one room so you can turn everything on or off at once at the tap of a finger or command to your smart assistant.
Vacation Mode makes it look like someone’s home.
Vacation Mode can turn your stuff on and off at random making it appear you’re home so people think twice about coming over uninvited.
Specs
Weight and Materials
Color
White
Weight
5.3 oz.
Dimensions (L x W x H)
2.7" x 2.0" x 1.5"
Weather Resistance
Indoor use only
Operating Temperature
-4°F - 104°F / -20°C - 40°C
Input
100-120 VAC, 60Hz 15A
Output
15A Max
Compatibility
Android 5.0+, iOS 9.0+
Certifications
ETL
Warranty
1 Year
Connectivity
2.4GHz WiFi
Integrations
Alexa, Google Assistant, IFTTT
In the box
- Wyze Plug x 2
- Quick Start Guide x 1
FAQ
Can I use Wyze Plug outside?
Wyze Plug is for indoor use only.
What else do I need?
Just the Wyze app and a 2.4GHz WiFi connection! Wyze Plug connects direct to your WiFi so there’s no need for a Hub. 5GHz networks are not supported.
Which appliances can I use with Wyze Plug?
Many "smart" plugs have a maximum load of only 10 or 12 amps meaning appliances that draw more power, like a TV, may not work. Wyze Plug works up to 15A.
Can I use Wyze Plug on an outlet that is controlled by a light switch?
Yup! Wyze Plug also “remembers” its last status so if you turn the switch off the Plug will return to its previous state when power is restored.
Is it possible to manually turn Wyze Plug on/off?
Sure thing! There is a small button on the side of Wyze Plug that you can manually press to turn the outlet on/off.
Can I fit two Wyze Plugs into the same outlet?
Yes! Wyze Plug is compact enough so it doesn’t block the second outlet.
  • Controls other Wyze devices
  • Works with an app
  • Works with Alexa and Google Assistant
  • Create schedules & use vacation mode
Control from anywhere.
Wyze Plug gives you a simple way to turn on/off any outlet remotely. Easily control, lamps, fans, and other devices from the palm of your hand. No hub required.
  • "The best affordable smart-plug" - PCMAG
Keep the lights off when you're at work
Save energy with scheduling.
It's time to the hassle out energy savings.
Create schedules for your devices to turn on/off automatically at certain times of day or when you leave the house.
Control with a powerful free Wyze app
Quick controls in the Wyze app.
Check to see if you left your Wyze Plug on and tap to turn it off remotely, right from the Wyze app.
Easily view daily and weekly run times and group multiple plugs together, controlling them all with one tap.
Use voice commands
Works with Alexa and Google.
Got your hands full? Command your devices using just your voice with Amazon Alexa and Google Assistant.
Make it look like you're home
Vacation Mode.
When enabled, Wyze Plug can turn your stuff on and off at random making it look like you're home, so people think twice about coming over uninvited.
An ecosystem that works together.
Your individual Wyze devices are awesome. As a team, the possibilities are endless. A light switch that unlocks the door. A lock that flips on the lights and cranks the AC. All of our smart devices can talk, what they say is up to you.
