Wyze Outdoor Power Adapter
Ready for rain, snow, or shine. Works with Cam v3/v4 and OG series.
Low stock
Ready for rain, snow, or shine. IP67 weather-resistant so you can safely use your Wyze Camera outdoors.
- Compatible with Wyze Cam v3/v4 and OG series.
Note: Outdoor Power Adapters will not work with OG Stack Kit.
Features
Features
- Easy installation, as simple as plugging it in
- Wyze Outdoor Adapter works with Wyze Cam v3/v4 and Cam OG series
- IP67 Weather Resistant
Specs
Specs
Color: White
Dimensions: 78.7 mm x 62.5 mm x 29.4 mm
Weight: 235 g
Cable Length:
Total cable length: 12.5 ft (3.8 m)
AC cable length: 3.9 ft (1.2 m)
DC cable length 8.5 ft (2.6 m)
Compatibility: Works with Wyze Cam v3/v4 and Cam OG series.
Powering Methods:
Input power: 100v-240v
Output power: 5v2A
Connector to camera: Micro USB
Connector to wall plug: 2 pin flat, US
Operating Temperature: -22℉ - 122℉ (-30°C - 50°C)
Weather Resistance: IP67 Weather Resistant
Certification: FCC, UL
Warranty: 1-Year
In the box
In the box
Wyze Outdoor Power Adapter x 1
Wire Clip x 8
Screw x 6
Attached Cable Wrap (White) x 2
Screw Anchor x 6
FAQ
FAQ
How long is the cable?
The total length of the cable is 12.5 ft (3.8 m), with the AC cord and DC cables together.
What accessories are included in the box?
Wyze Outdoor Adapter includes wire clips, screws, screw anchors, and a cable wrap. These accessories are designed to hold the adapter and cable to the wall.
Is a Wyze Cam included?
No, Wyze Outdoor Power Adapter does not come with a camera included.
What color options do you have?
Currently, the power adapter only comes in white.
Can I use this adapter to power any other product?
This product is compatible with other Wyze products that require 5V1A or 5V2A input. We cannot guarantee product performance if you are trying to use it for any other non-Wyze product.
