Wyze Video Doorbell
Wyze Video Doorbell
Small has never been mightier
Low stock: 13 left
Wyze Video Doorbell transforms your mechanical doorbell and lets you answer your door from anywhere using the Wyze app.
Note: Wyze Video Doorbell is a hardwired doorbell that connects to your existing wired setup. Wyze Video Doorbell is not wireless and is not battery-powered.
Features
Features
Instant Notifications
Never miss another visitor. Unless you want to.
Receive instant push notifications when Wyze Video Doorbell is pressed so you know the moment someone’s at your door.
Pull up a live stream of your visitor before responding to decide whether you’d like to ignore a solicitor or answer the delivery driver.
3:4 Aspect Ratio & 1080p Full HD Video
People are taller than they are wide. So is our live stream.
Wyze Video Doorbell records and live streams video in 1080p Full HD with a 3:4 aspect ratio so you can see every visitor from head to toe. You’ll also be able to see packages left on the ground beneath your doorbell.
Motion Detection, Smart Alerts & Video Recording
Wyze Video Doorbell lights up brightly when motion is detected nearby, alerting visitors and would-be porch pirates of your video doorbell.
Plus, you can turn on push notifications to get a phone alert whenever anyone or anything approaches your door, even if they don't ring the doorbell. Motion detection. Capture visitors with 12-second videos and stores them in the cloud for rolling 14 days for free.
Built to endure the elements
IP65 weather-resistant. Install Wyze Video Doorbell on your door without worrying about interference from the elements. IP65 weather resistance protects this doorbell from rain, snow, and sun.
Optional Upgrade Available
Upgrade to Cam Plus for $1.99/month to receive real-time alerts when people are detected and store full-length videos in the cloud for 14 days.
Chime Included
Hear your doorbell ring, chirp, or bark from any room.
Pair any number of Wyze Chimes with your doorbell so every room in your house is ready to alert you when someone’s at the door. One chime is included with each Wyze Video Doorbell.
Specs
Specs
Doorbell Hardware
Power Method for doorbell
Hardwire required: 16V-24V AC, ≥10VA
Power with existing doorbell-chime circuit, or use a standalone transformer and wires.
Item Dimension
Wyze Video Doorbell: 1.5'' width x 3.25'' tall x 0.625'' depth
Wyze Chime: 1.9685'' x 1.9685'' x 1.37795''
Item Weight
Wyze Video Doorbell: 1.7oz / 49g
Wyze Chime: 2.0 oz / 56g
CPU
1.5GHz, Ingenic T31
Image Sensor
2K (Resolution: 2048 x 1536)
Memory
128MB
Flash
16MB
White LED (Fill Light)
6 x 5000K (daylight color temperature) LED
IR Night Light
4 x 940nm Infrared LED
Camera
F2.0 aperture, 2.7mm focal length, 1/2.8" CMOS
Audio
Built in Speaker & Microphone
2-way audio
Noise & Echo Cancellation
Connectivity
Direct to WiFi (no base station needed): 802.11 b/g/n, 2.4GHz (5GHz WiFi not supported)
Sub1G: 906.8MHz, used for local connection between doorbell and chime.
Mount
Screw the doorbell to walls with
Wedge (aka corner kit): Tilt the angle of view 30 degrees horizontally.
Wall Plate - It would fix the doorbell flat on the wall
Weather
Weather Resistance
Temperature
Storage: -40 to 176°F (or -40 to 80°C)
Operating: -4 to 122°F (or -20 to 50°C)
Image Quality
Resolution / Video Definition
By launch: [1080p] 1296 x 1728 and [480p] 480 x 640
Future OTA: [2K] 1536 x 2046
Field of View
Vertical: 120 degree
Horizontal: 88 degree
Frames per second
Day time video: 20 FPS
Night time video: 15 FPS
Zoom
8x digital
Software
Operating Systems
Supports iOS 9.0 and Android 5.0 or later
Alerts
Push notifications
Wyze Chime sounds
Cloud Storage
Free rolling 14 days of Event Videos stored in the AWS Cloud
Data Security
End-to-end encryption
HTTPS secure transfer protocol
AES 128-bit encryption
Chime
Tunes (19)
5 modern tunes
4 classic doorbell chimes
3 animal sounds
6 sounds for automation
1 intruder alarm
Power
Standard power outlet: 100V-240V, 0.1A, 50/60Hz
In the box
In the box
Wyze Video Doorbell x1
Wyze Chime x1
Wall Plate x1
Wedge (Horizontal, 30°) x1
Wire Caps x4
Bracket Screws x2
Screws & Expansion Tubes x2
Extension Wires x2
Fuse x1
Quick Start Guide x1
FAQ
FAQ
Does Wyze Doorbell use batteries?
No, it is a hardwired doorbell.
Wyze Video Doorbell does not use batteries. It is hardwired, connecting directly with your existing mechanical chime power source.
Will my mechanical chime still work after installing the doorbell?
No, your existing chime won't work.
The existing chime will be bypassed so that the power can be used for your Wyze Video Doorbell.
Does the doorbell detect sound?
No, it only detects motion.
Your Wyze Video Doorbell can detect motion and people and has been optimized with a white LED light to ensure you see a clear face in the live stream. It does not detect sound.
Can I control the volume of the Wyze Chime?
Yes, in your doorbell settings.
To change your Wyze Chime volume:
1. In the Wyze app, tap on your Wyze Video Doorbell.
2. Tap on the Settings icon on the top right.
3. Tap Extended Devices > Chime > Tunes.
Is Wyze Video Doorbell weather resistant?
Yes, Wyze Video Doorbell is IP65 rated as weather-resistant. This means that it is "dust-tight" and protected against water sprays from any angle.
Does Wyze Video Doorbell require bridge or base station?
No. Wyze Video Doorbell connects directly to WiFi. It does not connect to the Bridge or the Wyze Base Station.
Is Cam Plus available on Wyze Video Doorbell?
Yes, absolutely.
Can I use the Wyze Doorbell offline?
Yes, but not all functions will work.
Once your Wyze Video Doorbell is paired with Wyze Chime, it will chime when the doorbell is pressed, even if the doorbell is not connected to WiFi.
However, the doorbell will not record event videos to the cloud or send push notifications to your phone if it is offline.
Does the doorbell come with a microSD card?
No. Wyze Video Doorbell does not support a microSD card. All recorded events will be stored in the cloud.
Support
Support
Wyze Video Doorbell records and live streams video in 1080p Full HD with a 4:3 aspect ratio so you can see every visitor from head to toe. You’ll also be able to see packages left on the ground beneath your doorbell.
Receive instant push notifications when Wyze Video Doorbell is pressed so you know the moment someone’s at your door. Pull up a live stream of your visitor before responding to decide whether you’d like to ignore a solicitor or answer the delivery driver.
Answer your door from miles away.
Two-way audio. Never feel away from home again with two-way audio. When someone approaches your door, just open the app to begin talking.
Pair any number of wireless Wyze Chimes with your doorbell so every room in your house is ready to alert you when someone’s at the door. Choose from 19 different chime sounds including traditional bells to birds chirping.
Built to endure the elements.
