Wyze Cam Pan v3
Wyze Cam Pan v3
Award-winning pan and tilt security, now weatherproof.
Wyze Cam Pan v3 is a redesigned indoor/outdoor, 360° pan and 180° tilt security camera, and is now fully IP65 weather-resistant.
*For safe outdoor use, Cam v3 Pro requires a Wyze Outdoor Power Adapter v2 (sold separately).
Features
Features
- 1080p HD Color Night Vision
- IP65 Weatherproof
- Remotely Spins 360°, Tilts 180°
- Automatic Motion Tracking
- Motion and Sound Detection Notifications
- Privacy Mode
- Easy Installation with Included Wall Mount
Specs
Specs
- Color: White
- Finish: Matte
- Materials: Body: Polycarbonate Lens: Glass + plastic
- Camera Dimensions: 124 mm (H) x 60 mm (W) x 63 mm (D)
- Camera Weight: 11.29 oz (320 g)
- Ports: 1 micro USB
- Power Cable Length: 6 feet (1.8 m)
- Power Adapter Input: 110-240V (AC/DC)
- Power Adapter Output: 5V/2000mA
- CPU: 1.5 GHz
- Memory: 128 Mb
- Night Vision: 4 IR LEDs (850 nm)
- LED indicator: Front. Red + Blue
- Video Encoding: H.264
- Video FPS: Daytime - 20 fps; Nighttime - 15 fps
- Video Resolution: 1920 x 1080 (1080p)
- Image Sensor: 1/2.9'' CMOS
- Digital Zoom: 8x
- Field-of-view: 120°
- Rotation Speed: Up to 110° per second
- View Range: 360° horizontal, 180° vertical
- Audio: Built-in speaker and microphone; 2-way audio; Noise & Echo cancellation
- Alerts: Push notifications
- Local Storage: Supports up to 256 GB microSD in FAT32 format
- Wi-Fi: 802.11 b/g/n, 2.4 GHz (5 GHz Wi-Fi not supported)
- Connectivity Requirements: Upload speed 1.0 Mbps for SD and 1.5 Mbps for HD
- Phone Compatibility: Android 7.0+ iOS 14.0+
- Operating Temperature: -20°C - 50°C (-4°F - 122°F)
- Integrations: Alexa and Google Assistant (pending), IFTTT
- Mounting Method: Screw 1/4'' - 20
- Circular Base: Diameter of base is 1.69" (43mm)
- Weather Resistance: Indoor and Outdoor (IP65)
- Certifications: FCC, IC, UL, TSCA, IP65
- Language: English
- Warranty: 1-Year
In the box
In the box
- Wyze Cam Pan v3
- 6' microUSB Cable
- Power Adapter
- Mounting Kit (Please note: There has a been change in our mounting bracket's design. Customers may get either design regardless of the design on the packaging. However, this shouldn't affect functionality.)
-- Bracket Screws x 2 (Screw size 3-24, thread length: 0.944")
-- Wall Anchors x 2 (Screw size 0.15", thread length: 1.181")
-- Binding Screw x 1 (Screw size 1/4-20, thread length: 0.335")
- Quick Start Guide
FAQ
FAQ
Q: What are the key differences between Wyze Cam Pan v2 and Wyze Cam Pan v3?
A: Wyze Cam Pan v3 has an entirely new, innovative design that doubles the total tilt range to 180º and produces 52% less dBA noise when rotating. It is also our first IP65-rated weather-resistant pan camera, ready to be used outdoors with the included mounting kit that lets you mount it literally anywhere - even upside-down. Lastly, it has Privacy Mode which points the camera lens down towards the camera body and obstructs any view.
Q: Is Wyze Cam Pan v3 wireless?
A: No, Wyze Cam Pan v3 is powered via a 1.8 m USB cable.
Q: What is the resolution of Wyze Cam Pan v3?
A: 1920 x 1080p Full HD.
Q: If I turn off Privacy Mode, will my camera go back to where it was?
A: Yes, it will return to its previous position.
Q: Can I use Wyze Cam Pan v3 outdoors?
A: Yes, Wyze Cam Pan v3 is IP65-rated and can be used both indoors and outdoors. Just be sure to cover the SD card slot to avoid water damage. Wyze Outdoor Power Adapter v2 (coming soon!) is required for outdoor use.
Q: Does Wyze Cam Pan v3 have a battery?
Q: What is the frame rate of the Pan v3?
A: Day: 20 frames per second (fps); Night: 15 fps.
Q: Does Wyze Cam Pan v3 support 5 GHz?
A: No, Wyze Cam Pan v3 only supports 2.4 GHz networks.
Q: Is Wyze Cam Pan v3 compatible with Wyze Web View?
A: Yes, Wyze Cam Pan v3 supports Wyze Web View. (Requires subscription to Cam Plus or Cam Protect) (https://view.wyze.com/)
Q: Does Wyze Cam Pan v3 support Cam Plus Lite?
A: No, it does not. Cam Plus Lite is only available on cameras released before April 2022.
Q: How do I turn on Color Night Viewing?
A: Wyze Cam Pan v3 is equipped with a starlight sensor that allows the camera to see color in extremely low light conditions, allowing you to see full color at night. To use it, turn off Night Vision in low light conditions.
Q: Why isn't my mounting bracket the same as what's on the packaging?
A: There has a been change in our mounting bracket's design. Customers may get either design regardless of the design on the packaging. However, this shouldn't affect functionality. Please check our support site if you need more details.
Indoor/Outdoor IP65 Weatherproof
Remotely Spins 360°/Tilts 180°
Automatic Motion-Tracking
Privacy Mode
Take Wyze Cam Pan v3 outside
Not just an indoor cat anymore. With IP65 water resistance you can automatically patrol your property in any weather.
Automatic motion-tracking.
Those cans never knew what hit them, but Pan v3 did. That's because it detects motion, follows, and records it automatically. Its upgraded tracking motor is quieter than a gossiping church mouse, so it won't wake napping babies or startle pets.
See the whole room with 360° pan and 180° tilt.
Now with double the tilt coverage Pan v3 can look straight up and down. Just like my middle school gym teacher, but way less judgy. It was an awkward time for me, okay?
Privacy Mode.
You just sat down to binge watch that show. You also decided that pants were optional today.
So, you enable Privacy Mode in the Wyze app and Pan v3 spins and points 180° straight down, eliminating it's field of view and turns off. You relax. You push play.
Watched a black and white movie recently? We haven't either, because every detail matters. That's why we've made Color Night Vision standard across all of our security cameras.
$150 Competitor Camera
Wyze Cam Pan v3
Two-Way Audio.
Packed with app features.
Motion and sound detection
Wyze Cam Pan v3 sends your phone instant alerts when either motion or sound is detected.
Custom detection zones
Smoke and carbon monoxide alerts
Set waypoints with Pan Scan™
Patrol your room with Pan Scan™. Set the camera’s patrol route with up to 4 custom waypoints.
